Hello
I've recently brought a T4 2.5 Tdi ACV with a 2.5 tdi volvo engine supplied. The ACV engine has a marking saying 74s and the volvo Engine has 74L. Only different i can see is the dip stick has a hole in the casing at the front.
Has anybody esle come across any other differences ?
The main internal difference is that the Volvo car version has smaller bearing journals (crank) as it does not have the torque load requirements of a commercial vehicle.
There are obvious peripheral differences i.e. manifolds etc.
There is only 1 difference in big ends on 2.5 tdi engine, the big ends are either 21.90mm or 24.90mm wide and is due to using sputter bearings or non sputter bearings . The 21.90mm wide big end bearings were fitted on 1T/AEL, d5252 t Volvo engine, AAT/AEL and ACV,AXG, AUF, AJT and a few of it’s variants as fitted on the t4 van...
