Hi everybody !!
I just start today to make timing belts replacement.
Had one problem with marks on flywheel // injection pump.
I have found one mark on flywheel and one on the pump pulley but both doesn't match together.
when i put marks on pump case and pulley aligned, camshaft is aligned to insert Template at the end side.
when i aligned mark on flywheel, mark on pump pulley is not aligned and camshaft is 90° offbeat.
is it possible ?
Thanks a lot for your help...i'm really upset !!
is it possible ?
