Was 215/65/R16 fitted to the T4 by VW? :*
Is so the pressure corresponding to that tyre size would be found either on the mentioned sticker or in the owners handbook
Definately check what the stick on the door shut says, then get as close to this without exceeding the maximum inflation marked on the tyre sidewall. T:
Thanks for respond guys..
forgot to mention,van is T4 888special..
van is use for work purpose so i would say is half loaded all the time..wheels r german spec carravell 16"bbs and tyres sugested by vw 215/60/16 and 225/60/16.Sticker inside the van shows only 15" tyre pressure same as owners book.Just put set of nice micheline tyres so dont want them to go flat to quick.T:
50psi is the same in a 195/70r15 as it is in a 225/40r18.
The tyre pressure is there to support the weight of the vehicle, it does not change dramatically from one size to another, just from one model of vehicle to another.
Get as close as you can to the pressure stated on the door pillar (regardless of size), without exceeding the pressure marked on the sidewall of your tyres.
I have a T4 Caravelle X plate Yr 2000 and am having problems with wheels. I was on holiday a couple of months ago and hit a pot hole that damaged my alloy wheel beyond repair and have been looking at ebay every couple of days to match up without any luck. The alloy wheels I currently have are 18...
Hi all my caravelle standard tyre should be 205/65/15 with load rating of 100
Does the same apply for winter/ snow tyres, we are off to the Alps next month I want not only the best snow tyres for the job but also the correct load rating and size.
Do vw recommend a different width for snow...
Does anyone have a set of banded steel wheels for a t4
I have either a set of Calibre 18 inch alloys in Black (two of the tyres are new)
a set of winter wheels 17" with new tyres
or a set of ATS Deepdish Rims 4x100 (For a mk1 golf etc) if anyone is interested, will upload pics later.
Ideally...
My friends I have a problem. I will show You my Multivan, it is lowered -40mm, and I want to change rims in it. I have bought DOTZ LAS VEGAS as on pictures 18x8H2, and now I am considering what tyres will fit. I must say I would like to have as much tyre profile as possible, and I know, I should...
