Has anyone fitted a replacement pipe for a 98 2.4D with a knackered cat?
Need some basic advice on how to fit a de cat pipe properly ie: joints, gasket leaks ect..
when inserting the gasket between the down pipe and the new de cat pipe do I just pop it in and tighten up or should I apply some exhaust paste at both new joints before I tighen up?...
Will a straight forward middle silencer{with flange} from other models replace my cat 2.4d, which one should i buy?
I see i can get a middle silencer from an older 2.4d online without the cat, will this be a straight swap?
Where can i source the right gasket and bolts?
Sorry about all the questions, would love to give this a go myself as my cat is gone in 3 places, the cat, the bend and the slieved joint and it sounds in awful! Was quoted 140euro in mayo to get job done, sounds a bit expensive to me??
Can I do this myself cheaper? and how do you fit this part?
Thanks in advance..
Thanks in advance..
