Will they be ok or is it gonna look silly, rub, or stick out to much? Here are the sizes
Front, 16x7.5 et25 with tyres 195/55 r16
Back 16x9 et15 with tyres 205/55 r16
Van is down about 85mm maybe abit more but don't mind going back up.
What you saying will they work/look ok??
sc vw customs 1.9tdi convert
unless you are sat on the bumpstops on the rear then you will rub with those et's etc..treid and tested that size....
loads of info on here mate about that rear size wheel and tyre..T:
Cheers dude any way of sorting that et on the back then? Maybe taking some off if that's how it works.?
you may be able to have some of the rear of the wheel skimmed off...but will depend on the wheel....thickness of mounting face etc...
