5 x 112 et 38 8.5 x 18
my van has been dropped 60 at the back and a fair chunk at the front, will I have issues with the arches catching and the sliding door opening ?
many thanks T:
I use 8.5x19 with slightly stretched tyres and an offset of 35, lowered on 85mm springs but with KW shocks. I didn't have any rubbing with the 4 steelies, tyres and a 9 stone dog in the back. However, the door rubber does catch on the wheels and there is literally 1-2mm clearance for the actual door. So it will be close, hope it helps.
Banned
i run 8 x 8.5
et35
225 / 40 / 18 tyres
van dropped a good 70mm
no rubbing
was a slight issue with sliding door solved by chopping rubber bung on back of door.
that et38 will save you 3mm anyway so should fineT:
i run 8 x 8.5
et35
225 / 40 / 18 tyres
no rubbing
cracking ta T: I collect the new ones tomorrow A:
don't they look poo with std wheel on :eek:
well got them T: they ain't arf big :eek: gotta give them a small refurb before fittng mind
