Apologies if this is not appropriate mods, but it's meant for those with the more sedate pastime.
For any of you gardners/allotment holders out there, I have some aerated polythene you can have.
Basically the stuff you put over your crops when you're getting them started straight in the ground.
The holes are 1cm in diameter and roughly a couple of inch apart.
There's a good 15 metres on the roll and when unfolded it's 10 meters wide.
Maybe it could be used for something else?
It's sat in my garage doing nothing. I can deliver it for a small cost within 30 miles of St Ives, Cambridgeshire (PE27 4TT).
If anyone's interested, send me a PM.
I guess it's too heavy to post/courier?? Would be good for keeping the weeds down on my veggie patch
Pete, the whole roll weighs a good 25kg and maybe slightly more. I can check at work for you tomorrow and get you a courier cost. I work in dispatch so can get some pretty decent rates.
If you PM me your postcode I'll find out the accurate cost for you. Off the top of my head you'll be looking around the £20 mark.
I work for a plant breeding company so it's proper agricultural polythene, hence the 10metre width.
Thanks for the interest by the way, Nick.
