I have the AHU engine from a 1995 golf i removed from my T4 as i wasn't happy with the standards the previous owner had done the conversion to, i started fresh with a newer engine.
This engine has 150000miles however ran brilliantly and pulled strongly.
It has been drilled to take the T4 bolts however these need rethreading and a broken bolt needs removing after the van sheared its driver side mount (i can do this for you if requested). I also had issues with a torqued drill bit when i attempted to drill the rear dipstick, this has since been removed - a pilot hole exists in the block for the dipstick swap to be completed, however i tried to grind this out and so i have applied epoxy metal to the ground slot and dipstick pilot hole to plug it. This is a low pressure area of the engine so it was perfectly fine when ran like this. I am more than happy to drill for the rear mounted dipstick upon request.
The engine is otherwise brilliant, it has a passat oil pickup and sump on it for the time being as this wasn't required when i redid my conversion. If you don't want these i can remove them and charge you £10 less.
I'm asking £200 for the engine, and can have it delivered for another £65.
Alternatively i welcome collection from DL15 (County Durham).
Pics available upon request!
Discussion Starter #5 (Edited)
Right guys, anyone interested, i'll flog this for £140 THIS WEEK ONLY.
I return to university Friday so want it gone before then, otherwise i'll break it for parts to keep as spares for my own van once im home in the summer.
£140 collected can have it, must be BEFORE Friday 12th 2013.
I'll send you my mobile number if youre interested, just pm me.
Thom
P.s i can supply information of the car it came from to prove it's legit etc.
Picture:
Price of £140 stands and will until this is sold now as we need the space. Engine is to be collected from DL15 0HJ and payment must be made prior by paypal (as im at university).
The engine was in excellent running condition when removed from the van and had regular oil changes throughout its use.
Requires the engine mounts redrilling and the dipstick hole finishing.
Any interest please PM me.
