Ok Im new here and have read most of the posts on this subject. I am no expert but can find my way around most problems (With the help of youtube usually).
Blower motor was making the annoying squeak at all speeds so i took it out and greased it. This stopped the problem for about a month. Tried the fan the other day and its dead.
Have taken motor out again and tested direct from the battery and it runs fine. I think the brushes are worn a bit but there is 3-4mm left on them. Had to fiddle a bit with the brushes to get the motor running. Put back in van and its dead. Resistor looks fine. Cannot find the fuse position in the box but have checked every fuse and they all look fine. Any suggestions?? 2009 1.9 tdi t5.
