**SUMMER OFFER**
Air-Con Refill for only £40.00!!!
Did you know that your Air-Con system should be checked regularly?​
It is recommended that you should recharge your Air Conditioning system with gas and lubricant every two year to keep it running efficiently. A drop in gas pressure will result in a loss of cooling efficiency as well as making your engine work harder (which, in turn, means more fuel). Remember, this is not usually included in your car’s annual service.
Here at TVS our fully trained technician will adjust Air Conditioning lubricant and refrigerant levels in line with the manufacturer’s recommendation all for our special price of £40.00.
Our expert technicians will check the Air Conditioning lubricant and refrigerant levels in line with the manufactures recommendations.
*Subject to initial inspection*
**Unfortunately this offer does exclude: Hybrid & electric vehicles**
To arrange this service please call: 01827 251376
email: [email protected]
or email us via our Facebook page.​
Thank you, Tamworth Vehicle Services Ltd​
