I've completely boxed in the rear nearside but havent done the rear offside.
When I close the boot the air pressure inside is preventing it closing first time unless I really slam it. If a window or door is open it closes with normal force.
I assume the outlet vents are in the sides below the floor level- do you think blocking one of these is causing this and therefore will blocking both make it even worse?
cheersT:
yeah if you blocked them this will stop the boot closing easy, if you boxed them in fit a vent cover and that'll cure the problem both sides
T:
