1 - 20 of 59 Posts
Well the static guys have some dedicated threads, post your pics up guys, we all love pics T:
Might as well add my 2p worth.
It's still running about 40psi in the back in the above pictures.
- Re-built Havair/Gaz front struts
- Custom rear bags & Mounts with Gaz Shocks
- Twin Viair 444c Compressors
- VU4 Manifold
- AVS Switchbox
- 3x Viair Gauges
- 5 Gallon Seamless tank, underneath in front of spare the wheel
All fitted by yours truly T:
Airlift V2 management System
Airrex struts and Bags
Two 2.5 Gallon Aluminiumtanks
V2 Manifold (all fitted underneath in front of spare tire)
16" Standard Steelies:)
...is it possible to do the hub mod with Air?
Administrator
I quite like the look of the havair front struts, I've not heard any negative comments on them and they will probably be the ones I go for once I have finally sorted other issues out on my van.
Someone had a rayvern set up fitted earlier in the year from on here but never heard any reviews or feed back from them about what it's like.
- VU4 Manifold
- AVS Switchbox
- 3x Viair Gauges
How hard was the install process?? I take it all the struts are direct replacement so it's just running the lines etc.
Administrator
Just ordered my bags for the rear, Festa has a spare compressor in his garage so going to have a look and see if it's suitable..Going to go for Havair front struts and probably go the solenoid route
1 - 20 of 59 Posts
