hi
i just fit a silicon warrior alarm to my t4 followed the instructions and every thing including wireing to the started motor so to act as imobiliser as instructed, but now my cd player wont work when the van is running only when the ignition is clicked to acc position. Getting rarther confused and annoyed with it all now. Has anyone got any ideas how i could get around this thanks.
Discussion Starter · #2 ·
i have now just remmoved the fuse from the alarm system and now the cd player still wont work properly. it worked perfectly before the alarm was fit or should i say befor i started messing. thanks
Sounds like you have cut an ignition feed to use as an immobiliser, you need to retrace your steps and check what wire you have cut. And then check which wires on the alarm you used to immobilise, you might have picked the wrong pair if it has 4 immobiliser wires.
Not familiar with that model of alarm, do you have a diagram?.
*EDIT* Also, does this alarm use external relay/relays for the immobiliser?
Make sure you haven't dislodged a fuse when working on the fuse box.
thanks guys i will check both of these tomorrow as i have a full day trying to get my head around this. any advice is much appriciated thanks.
