previously known as: first t4
does anyone know how to take the arm rest off an alfa 156 driver seat as i'm leaving the double passenger in for the time being
thanks
quite easily
peel back the leather where it joins back of rest lift the foam and you will see wire ring through a plastic sleve pull the wire to release the sleve and pull the arm away.yo are hen left with a plastic rod held on by three allan screws take them out and the rod comes off.job done. you are left with a hole in the side of the seat .i'm going to try and get a vw badge of some sort to cover it with.
