1 - 11 of 11 Posts
I have a set of alloys lying around from a previous vehicle. They are as follows
PCD 112
8Jx17H2
ET 35
If my understanding is correct then rim wise they will be fine.
However, the tyres they are running though are 215-40-R17 . So fairly low profile but narrowish.
Would this set up cause me any problems on a T4? Van is a 200, currently not lowered but thinking 50mm or so in the future.
Any advice apprecaited
Si
Whats the load index and how does it work? the high the number the better? W Stands for?
Just run outside to have a look and its seems im running 91H which thanks to your chart says has a load rating of 615KG
Ive got a 1.9 SWB T4 Panel.
Any issues?
Thanks for the advice and chart.
I have noticed I can't spell
Read the tech articles bud and understand what you are doing :) :ILU:
Post up and listen to chaps like Colse if he is running that then happy days assuming you are not loading you van any more than he is; I learnt a lot from him and Clintharshaw when I was in the same situation.
1 - 11 of 11 Posts
