I've spent hours on this forum looking at ignition timing threads. I've had more Golfs and Jettas of all Marks than I care to remember so I've looked through the Golf Mk2 and Mk3 Haynes workshop manuals and I've looked on Google, Club GTi, Vortex etc, but I don't seem to have the same set-up as everyone else.
I have a 2L AAC, 1st registered November 94 on an M plate. It's got Digifant EMU with Catalyst. I only have one mark on my flywheel, the diamond shaped one, no circle for TDC that I can see. The van runs and ticks over pretty well, but I can't help feeling it could hold it's power better on hills and give slightly better MPG (I get around 22mpg).
I've checked the ignition timing with a non advancing xenon timing light (an old Draper), at 2250rpm with the temp sensor disconnected there is no sign of the timing mark in the Bell housing window. Moving the distributor both ways just makes it run rough but doesn't bring the mark into the window. The distributor's rotor arm lines up with the notch in the body at #1 TDC, but there does seem to be a lack of timing marks compared to my old Golfs.
My questions are:
1. Is the diamond shaped mark in the cut out in the flywheel TDC or a ignition timing mark (6deg BTDC)?
2. Should there be a 'O' for TDC as with Golf, I had that on my Mk3 ADZ engine?
3. Do I need an advance timing light to do this properly?
4. With the Temp sensor disconnected it's a bitch to rev to 2250, but starts okay - is this normal?
5. Is there a decent workshop manual available for the T4 I don't know about, Is ERWIN any good?
I've been using this site a fair bit, but somethings not the same between my van and his descriptions. I'm starting to wonder if the cam belt change was done right last time: http://fuelie.tripod.com/tuneup.htm
Any help would be much appreciated.
My questions are:
