Hi. Not sure if anyone else has this problem but on my early J plate LWB t4 i was looking to fit some rear belts. Ive got hold of a bongo seat and runners and cant seem to find where to put my belts. I have read on some threads to use the belts on the actual seat but i do have the fittings to put them on the van. Trouble is i dont have any captive nuts on/in the pillar to put the high bit of the belt. I hope you know what / where i mean ? Is it an easy enough job to put a plate in behind ? as the holes are already there for the belt mountings.
Cheers T:
You can buy the captive plates from VW
BUT
Seen on here somewhere that if you have a panel, van the pillars are NOT designed to take belts as they are made of either thinner metal or aren't double skinned.
This info could be wrong so double check to be sureT:
