Hi guys,
I recently bought a T4 and it came with these wheels and tyres on it. I am looking to change them back to standard 15inch steel wheels and once I do I don't see the need to keep these so would look to sell them. I have no idea what they are from or how much they are worth. Does anyone have any idea?
Cheers,
Matt
184895
🙌🙌 that looks like them! Thanks mate. Now to find out if they are genuine, if so hopefully worth a bit!
Cheers,
Yeah, that’s why I’m changing them. Says 690kg on the rear of each wheel. Think this should be 900kg right??
Full of Cr*p....
Depends on the van spec.....but the weight on the front is often higher. (Big engine!)
Check the weight stated on the door pillar, it will tell you the Axle weights.
A 1200 VAN will have higher rear axle....due to having a possible 1200kg over it......
See this thread:
Means for mine, it's 775kg per wheel. (And tyres rated at 99LI minimum).
