1 - 14 of 14 Posts
Its about time I showed up
Discussion Starter #5 (Edited)
If i add a spacer to the et 24 making it et 14.. Would they go on the rear?
Would want to run a 205 50 16 or a 55 maybe. Vans on e30 springs with rear bumpstops cut. Its not that low really but quite.
this is 9J, ET 11 with a 205 55 16 on Jamex springs, unloaded mate if that helps T:
Discussion Starter #11
Cool.. Thanks Keef :ILU:
Will be more space with a 50 profile T: Should fit like a glove then :cool: Im hopeing it will improve the ride a little too.. My tyres are way to skinny for my likeing.
Looks like im skint again now then :rolleyes:
These are mine, 16's 8j fronts & 9j rears - believe they are below et 24, maybe 12-15 on the rear (I'm sure colese will update as I bought these from him a while ago).
I went for the slightly chunkier tyre to most, im running 215/55/r16 all round - got to space my slider more than the wedge as these tyres have quite big sidewalls so my door gets about half way past the wheel then gets stuck. Oh, and I'm down 60mm on T4SRUS springs - unloaded in pictures.
Hope these are of some help :)
1 - 14 of 14 Posts
