1 - 12 of 12 Posts
Yup, I've got one - I'm building it into my camper.
It's brilliant to use - absolutely fab.
Quick and clean.
But you do need the right pans - it won't work with some pans.
You shouldn't have a problem with a normal hookup.
got one ! T: these may be a great addition to anyone who has a smev one burner and sink if this was fitted it would allow you to register as a camper . could be £30 well spent . I:
I use induction at work, faster, safer, cleaner, cheaper to use quicker to heat up, (less power used), and until now very expensive! :D
I've got an induction hob at home. It protrudes about 60mm down into the worktop and I had to lift the worktop 10mm to allow a ventilation gap. Its been perfectly reliable over the past 15years.
If it was in a camper I'd carry a little briefcase gas stove as a backup.
1 - 12 of 12 Posts
