I: aahhhhh miss read your post karlos. Thought you were running your tapered ones. Not got any knowlage of running steel bolts in alloys. Think the only issue would be the length of the bolt . If they protrude the rear of the wheel hub by a few mm they should be ok for now. But I'm sure there will be a thread on here about it offering you some correct advice.
I: I bought a cracking set of alloys advertised for a t4 and came with a set of wheel bolts. Well when they arrived the bolts were the right tapered ones BUT only 25mm in length
. I spoke to the fella to say a 35mm was recommended but he said they would be fine.
I won't be running them I luckily have my old set that are 35mm so will use them. It goes to show not every one has safety in mind and the "that will do "attitude is bad , so it's always best to check and double check. :ILU:
