Hi all,
My auto caravelle gearlever control switch seems to be having issues. When in 'park' it shows on the dashboard display as being in 'reverse'. When all other gears / out of gear it shows the correct display so not sure where the problem is. In order to start her up I turn on the ignition halfway, move the gear lever to 'neutral', depress the brake and switch her on. Absolutely no problem with that system but might be nice to work out if this craziness can be remedied.
To add to the confusion, sometimes the display decides to black out and shows a black background with all gear options lit up as if they were selected...
I'm hoping it is simply a case of replacing an electric switch of some kind in the actual gear lever itself but if anyone has come across anything similar before please do get in touch!
cheers
Beaker
