hi all ive got a t4 2.5tdi year 2000 swb auto
ive had the gea:(rbox fluid change
my problem is when driving my bus up to 50 mph the rev counter moves up and down and the bus drives like a kangaroo any help please
have you had it changed 3 times with the right oil and checked for level at the right temperature on a computer? if NO to all of these,then i'd get it done correctly if i were you. cheers mcgill
Sounds like the Torque converter is not locking up, and the gearbox is slipping when using the hydraulic coupling.
Did the problem start before or after the ATF change? Did you change the filters, did you notice much debris in the sump?
Don't drive it till you get it fixed, if it overheats and locks up completely it can hurt the pocket.
hi i took it to a auto garage they changed the oil and filters it was ok for a bit then this only now again this happens anymore more advise please
