hi,Ive got a 2.4 auto 92.Its been stood for 1 year,It worked ok before,now its not changing up till aboat 3k revs,and wont go into top gear,is it a shagger,or would it be worth changing and filling the autobox with new fluid/oil,or is there anything else worth trying.
Hi
I've got a feeling that this is a common problem with auto-boxes and I believe that in some cases a simple ATF change can improve things.
If you've never done an ATF change this would be the place to start.
However, If I remember rightly I think that the main cause of this is the N91 or N93 solenoid.
Have you got VAGCOM? Can you run an error check on the box?
I know that crazant is in the process of replacing his N91 solenoid, but I can't remember exactly what his symptons were.
Might be worth dropping him a message.
