thanks
it took about 6 hours in total to just remove inlet manifold and clean i scraped what i could out and gave it a blast with care cleaner,theni used a full tin of Mr muscle oven cleaner over night .a good scrub and jetwash then set about it with a palm sander with 80grit working it down 120 then 240 with a block and by hand in the hard to get areas wipe with methanol spirits and then set about it with wet and dry 240, 600 and 1000grit finishing off with autosol and lots of soft rags(old dressing gown ) the sending and polishing took what seemed like a lifetime as i split it over a few half days and evenings into the small hours to
i also did the same to egr valve and rocker gasket
i now have shiny bits but no finger prints
