hi guys i have a 1994 caravelle with a floor heater thingy in the back under the floor it seems not ta work was going to check the fuse the hand book says its fuse no. 25 but they only go to 22? any ideas where i find the fuse for it?
RIP
TBH I ditched mine. Weighs a ton, and works off the hot water system if its that same as mine. I dont carry rear passengers much, and even then the heaters only used in the cold. As I fitted a Propex so that provides heat in the rear if needed.
Pretty easy to remove. trying to remember the wiring, but cant, sorry.
