1 - 13 of 13 Posts
fitting some uprated avo shox tomorrow all round is there anything i need to look out for when fitting?
If you've fitted dampers before bud you shouldn't have a problem,pretty straight forward,i would set them mid way to start and go from there.I started hardest setting first and worked down.Happy fitting!!T:
Gaz.
There's several threads on here if you do a search on damper fitting which should help,didn't know Avo did a set of non-adjustables for the T4??:confused:
Gaz.
I've never seen non-adjustable yellow Avo's ?? just looked up Venom Motorsport where i got mine and the part no is correct TG 1257.
Gaz:confused:
Banned
I rang AVO today about this.
AVO, back in the day used to do some budget dampers, but they never did them for a T4.
AVO have never done and yellow dampers, nor have they ever made any non adjustable dampers for the T4.
Obviously I had to let them know incase there are inferior quality parts out there claiming to be AVO products.
This was news to them, not heard of any more cases.
As I think the saying goes, I think you've been had.
1 - 13 of 13 Posts
