If you're wanting to fit it under the poptop hinges etc.. then I think you need this one that rises out of the roof channel. The one you've posted will get in the way.
That is the link to the type that I fitted.
I’ve seen one on the net mounted vertically in the channel, so going to see if it possible. Don’t fancy taking off the hinges and strut
No issue taking the hinge bolts out of the roof and slide the rail under. I released the strut to get the rail under, but I won't bother again it was a pain getting it back in due to the tension. Just trim the rail around the foot of the strut.
