Several 130 or AXD and 174 or AXE motors have had 'Catastrophic failure' documented on this forum,it would be interesting to see if it is a repeating scenario.
It starts with a misfire,progresses to difficult starting with pointing uphill/downhill sometimes making a difference, and ends with a runaway engine dieseling or just non start and diesel fuel in sump oil.
A denmark VW tech has posted that there is a cracking problem on #3 cylinder in the cylinder head. I:
Whilst rereading http://pierro777.free.fr/DOCVAG/2.5_TDI.pdf the drawing 305_020 shows the close proximity of the pressurized fuel gallery to the inlet port.
If these two were to connect would that cause these failures?
