Wondering if anyone has any good ideas about what would be preventing my rear doors from closing properly at the bottom catch using either the inside/outside door handle?
I have taken the panel off and the insulation out and checked the long rod - it is fully tightened up at the top and connected in at the bottom. Put some oil into the bottom catch mechanism as well.
If I close the door by slamming it from the outside, then it closes properly at the bottom without any issue. But as soon as the inside/outside handles are pulled when the door is shut, the bottom catch is not engaging.
Any suggestions would be greatly appreciated!
