Hi
My battery light flashing on when I accelerate through the gears .
Soon as I ease off it goes off .
If van is standing it doesn't appear.
Changed alternator, cleaned up terminals ect .
Any ideas please .
Full of Cr*p....
Check power and earth cables/connections.
As you move, they will pull/push and so maybe lose contact.
Earth cable is a common failure, as they are often bare copper and corrode.
You should also check the small cable that goes to the alternator...another known weak point.
Well I've had a look at all obvious leads and can't see anything loose so back to drawing board I suppose.
