Hi I've just bought a trident t4 motorhome and i need to change the battery .Where is the battery retention screw ? Simple i know but I'm new to this.Thanks in advance :ILU:
presume a bolt on a clip at the centre bottom front of battery, like ours
the plastic battery area covers just pull off, air intake cowl 2 clips at top then pull up & out, squeeze pollen filter at rear & pull out
the bolt shouldn't be, just a socket on a short extension
worse things to come no doubt :D
get some pics up if you can
GL with it, the world's now your own..................................
