1 - 20 of 22 Posts
Any ideas??? my battery seems to be running flat after a couple of days, The battery was fully charged, put on 3 days later flat.. tried another battery same problem...I have fitted a different stereo and though it may be this so removed the stereo fuse...guess what still goes flat??
Any ideas? obviously all lights are off....:*
Unfortunatly no multimeter! I removed the fuse from the fuse box that powered the stereo...would unplugging make a difference??
Thanks for the reply!
T:
Although you have pulled a fuse, it might have been a fuse for the switched side not the perm live, also someone may have bypassed something. If this started when you fitted the radio I would pull the plug out of the radio and see if it changes it, then take it from there.
You only need a cheap multimeter if you can get your hands on one, set it on current/amps (10A)and disconnect the negative terminal from the battery, put one probe on the battery terminal and one on the cable that goes on the battery, don't put the cable back on the battery though. Then have a look what the amp reading is, but don't turn the ignition on as it will blow the fuse in the multimeter. Make sure everything is switched off in the van, let the reading on the meter settle as electronic units will start up and then settle.
O.k.....
Removed the stereo completly and fitted a new battery left over the weekend and went to it last night it turned over a few times before the battery gave up...
Any ideas???
some kind of drain happening, l had similar issues recently, turned out to be alternator
local electrical mech did a test, tested everything, l did not have a clue
based on his test, he felt it was alternator was gone, looked at reconditioning, 15 years old, so opted for new
runs like a dream, let a good electrician do their tests, better than struggling for weeks and doing loads with no results, keep us posted
Discussion Starter · #8 ·
Someone else has mentioned the alternator....
Its deffo not the Starter motor as with a full battery it jumps in to life and its also not that old....
test are often free .just finished my bosch alternator and oem fuse box in front of battery ,make sure the garage cheak both ,as mine didnt ,not fun driving 60 miles home in dark, with no lights:eek:£300 alltogether :( but got lights and heatersH:H:
Hi
Had a similar problem recently it turned out being the secondary electric Water pump not
turning off, faulty sensor. Perhaps a possibility......
/mike
It's a common cause of battery drain. If you listen under the bonnet you can hear it running.
My battery is running flat, desconnected radio and using multimeter on the 10 amp setting get a reading of 0.02 is this normal!!
Bet you it's the alternator. Had the same problem for months. A new alternator fixed it. Got a bigger capacity battery fitted while I was at it and all is well!
J
Yes, that's normal. The cold weather will find any weakness in your battery so get it checked at a battery specialist.
Tuesday morning, went to take my daughter to school and the engines turned over a few times and battery died, she had to walk to school. Put battery on charge for 24 hours, turned key, all normal lights on dash come on, relays under dash clicked but nothing from starter. Tested battery its fully charged. Tried hitting starter with a hammer.
So I have rung a mobile auto electrician who is going to come round tomorrow morning at 10 and look at it :* only 3 weeks ago she had a full service, cam belt and a new alternator grrrrrrrrr
Most likely to be the red/black wire to the solenoid. The spade connector gets a bit corroded, normally a bit of clean sorts it.
1 - 20 of 22 Posts
