Couldn't post on here yesterday so put on T4 site.
Battery running flat because BCM not going to sleep. Remove fuse 3 and relay clicks off. Put fuse back in and unit stays off until you open a door . Have noticed in the past that sliding door doesn't always lock. Also immobiliser led doesn't always flash regardless of wether door is locked or not. Also, sometimes the van auto locks When doors have been opened and closed.
Have read threads reference wire under driving seat, also downloaded J519 info but nothing seems to tie The two together. Any ideas?
Currently connected to battery minder if not used for a week or more. (Battery flat, 8.4v, after 6 days)
Thanks for your help.
