Need to sort out a roof bed and wondered what Reimo use for theirs.
Normal ply or something stronger?
Pedal box guru
They use normal ply with aluminium channel to give it strength. then join the boards with piano hinge (if you go for a "Z" bed option)
I have several lengths of the channel if you need some!
Cheers Trev.
Meithered to death
Hey fella i made my own some time ago and used 15mm marine ply cut to the correct length and width by the woodshop i bought it from,so then after it was a direct fit for the roof's strenghtening frame and just needed hinge fixin at the rear and a couple of gas struts to hold it up out of the way until required.Oh and a sheet of 2" foam and some inca cloth to finish it off nicely T:
Cheers Trev.
Trev, when you say channel, do you mean like a 'U' shape to fit over the edges along the lengths of the sheet?
I just want 1 flat sheet rather than the 'reimo' type
Steve, Exactly what i'm hoping to do. How much weight would you say it would take? I am a fat :*
LOL:
Luke, get yerself round to Wessex Trailers mate, you'll get some f'ing solid 18mm marine ply from them, don't know about price but worth a try.T:
Meithered to death
Luke mine will easily take my weight and i reckon im taller and fatter than you.
If your in no rush then hangfire until Holton and have a look at mineT:
If you want to know anything sooner then PM me on the other side and ill drop you my phone number
:cool:
