1 - 20 of 22 Posts
No 19's it's took me about a yr to complete the set odd wheels etc / refubish tyre's pcd's...Ttyres are accellera's 245 45 R19's load rated / speed rated.
Once dropped will i need it re- aligned:*
Discussion Starter #8
Thanks maxx have you pulled your front wheels in yet.
Was thinking about getting the front spacers machined 2/3 mm to bring them in but without taking the safety aspect out of things.:*
Discussion Starter #19
Cheers for the commentsT:
Bumble would you recommend anywhere getting the alignment done been reading up and do you have to have it setup a different way than if it wasn't lowered. If i took it anywhere trying to explain to someone how to do there job isn't very welcoming if you no what i mean especially when i don't no what i mean.:*
i can see the pictures now! very smart! T: seen them before :* aha umm nah i havent pulled mine in yet. Was going to look at maybe some 18mm steel adaptors, but as mine has stupid tyres on it its not to bad atm heres how mine sit with it low
front
rear
do miss mine black a little bit! good work :ILU:
1 - 20 of 22 Posts
