I can see there are many ways to board the sides before carpeting but can anyone tell me the best way as id like to only do the job once. Thanks
You can cheat and buy a kit..all the panels will be there ready to self tap into place..easy as especially if its the first time youve attempted this..
Or you get a lot of brown paper and make templates and then screw the panels in place..
Before you start though check all the little nocks and crannies for signs of rust and treat them..Get yourself loads of insulation and do the job well..theres lots of threads on here on insulation...i personally use cotex from wickes or simular for the big panels and rock wool in breathable membrane for the the little bits behind ribs etc..foil bubble wrap over this and in the roof void..all held in place by miles of gaffa tape...under the floor the fibrus sheets to go under laminate floor work well...
Just over kill now or you'll regret it in a while..T:
