Hi all,
I've got a bit of a black smoke problem on my 1999 AJT 88hp 2.5tdi. Basically anything over 2.5k/3k revs and I get a lot of black smoke out the back of my van. I know there's a fair few threads on here about similar issues but in my mind I've checked most things so wanted to know if anyone could suggest anything else?
I've done PP2, so injectors from Ron (Rake), l200 intercooler, pptuning exhaust (decat), egr blank all the usual. I've also put in new glow plugs, oil change, filters changed new Maf (map) sensor and had a full belt change as there was some serious bodging going on by the previous owner and all my timing set up by VW (this was costly!). I decided the lumpy idle from the pp2 injectors needed sorting and vw couldnt do much for me so went to see Wayne of Chipwizards as he had some time to fit me in before xmas and was a bit closer than pendle to get the van mapped.
Things were going well until Wayne noticed that I had hardly any boost, so set about testing my N75 and discovered that the pipe connecting it to the wastegate actuator seemed blocked so left this disconnected so he could map my van as best as possible which did get my boost back. This is still disconnected but I should be fitting a new pipe this weekend. I:
Obviously I'd had this problem from day one and the initial hp was only 69hp instead of the 88+ I was expecting my van to now be on. Wayne then set about changing my ecu chips (older van) and mapping the van - all went ok but I was getting smoke so we decided to drop it back to 129.5hp for less smoke (I had thought I'd get more from pp2 without smoke but all vans are different). Van now drives great and I can hear the boost coming in etc etc...
Now I have it home and have been commuting it seems I'm driving slower (keeping revs low) and short shifting so I don't blow a big cloud of smoke out the back and I'm wondering if there's anything else that needs checking as the map may have highlighted an existing issue?!? :*
Also the van still seems to have a problem with any incline. e.g. if I hit an incline at 70mph on a motorway it then slows up quite a bit as it doesn't seem to cope well. And in all honesty it doesn't really want to go past 70mph it seems.
I'll probs try getting hold of Wayne again to see if he has any ideas but he's super busy and he was in the process of leaving his workshop while I was there. So not sure he'll be all that available at the moment.
Hoping that the forum can give me a few paths to investigate?
Cheers in advance! T:
