1 - 20 of 37 Posts
I thought I'd share the look.
As you can see I have "a thing" about blue LEDs
Dash lights
Even the indicators.
Cool Blue:ILU:
changing the illumination is easy.
1. Remove the column cowling
2. Remove speed surround
3. Remocve the clocks (2 screws)
4. Change bulbs
5. Remove green film (if you are lucky you can grasp with pliers otherwise you may need to take the front off the speedo (easy job, 2 screws.)
Reassemble. Job done
Indicators alittle more tricky. You need to gain access to the rear of the led indicator bulb which needs unsoldering and replacing with an LED with the appropriate resistor.
I drilled a hole big enough to do this, carefully:ILU:
:cool:i like this blue look is it a certain bulb for the job ?:ILU::ILU::cool:
got them off fleabay. Think they are called T5 bulbs
Check the pics to make sure you get the twist fit ones.
Discussion Starter #8
Are they standard clocks? Apart from the lighting that is?
Yea standard. Just changed the 3 illunination bulbs.
Oh, and the indicator bulbs to blue also.
What year van ya got bud? Only askin' as not seen em that style with the rev counter?
Maybe I'm jus being blind:D I'm still livin' wiv a golf set of clocks after conversion so massive gaps in dash, must be able to get a set of them to work? Well I'll prob have to pay someone else to do it for meLOL:
Discussion Starter #11
99 on a "T"
just missed the blue clocks
Discussion Starter #13
Three bulbs mate
Me too,
Couldn't suss how to change the clock/milo thingy colour. Beyond me.
There is a company called DDI (dub design industries) in the USA that do new faces for your clocks that light up white.
There middle one not working as it needs a soldering repair but quite good me thinks!!!
Discussion Starter #16
Nice. Am liking thatT:
Somebody stop me!
They dont list the T4 on their site though :(
i changed these on my t4 does any body no how to increase the brightness they are as dull as anything the dimmer switch is on full ?????????
1 - 20 of 37 Posts
