1 - 9 of 9 Posts
Hi all
I have just got a set of two 3 seat bongos with floor rails. not sure how to fit the rails. Any advice? ( not you should have bought vw ones)
Thanks Bare101
I hate to have to rip out the ply lining but needs must. I will post some pics with the results.
Thanks again
Hi guys, did you both remove the fuel tanks to do this? I didn't see that on bear101's thread. Thanks again.
Didn't remove the tank just dropped it down. So put a trolley jack under the back of the tank with a bit of wood to spread the load. (make sure your low on fuel) then remove the 3 tank straps and just lower the tank about 5 inches. The front of the tank stays fixed in so it just drops the back.
1 - 9 of 9 Posts
