Ive lowered my t4 van 45 mm using eibachs & now lowered the front to match
can anyone advice on the adjustment of the rear brake bias
its also been through a mot like this too,,there's no locking up of the rear brakes at all hand brake holds the same,,although the brake fluid is looking a bit worse for wear so think this spring i will renew that along with a full braided hose kit & rear disc"s/pads as it was advised on mot the rear pads were starting to show uneven wear, so sod it start again & renew them T:
cheers
