Just been out to change the rear pads on my 1.9td, as i noticed that the rear drivers disk has not been working properly as i could see rust marks that were staying when all other disks were being rubbed clean with use.
i managed to get the old pads out and just about got the new ones in place (no wind-back tool, but an angle grinder disk changing tool worked pretty well). Following the changing pads on a 2.5 tdi sticky thread, i took the main caliper off, leaving part of the calliper housing still attached to the wheel/disk bit, by removing the 13mm bolts, not the 18mm ones.
I noticed that the 13mm bolts are on some kind of 15mm moving bolt(?) that i guess moves when the brake is applied squeezing the pads onto the disk. The top 15mm bolt is free to rotate and move in and out, however, the bottom 15mm bolt was seized tight and also not quite sitting square to the calliper. I think this was why the brake was not working properly. When fitting the pads back in, the top 13mm bolt went back in ok, but the bottom 13mm bolt didn't line up to the 15mm bolt/hole.
I tried to move the 15mm bolt but i've ended up shearing it off and now i'm unsure what my options are as to getting working brakes again.
I've shamelessly stolen one of the pics from the changing pads thread and marked with the red arrow the part that has sheared.
Can this sheared part be removed and replaced? there's not much extending out to grip. Do i need a whole new caliper, or can i get just the part that bolts to the disk bit? i had a quick look on vagcat but couldn't find any part numbers for rear disk brakes, one of the front ones looks similar, but i'm sure they will be different. I don't know how different the various brakes are, but i know the local motor factors brought out several pads to check i had the right ones - they have a wear sensor too if that adds to the confusion.
it's not a massively urgent job as i don't use the van every day, but it would be good to at least get the new parts sorted sooner rather than later.
any help would be great, cheers.
