Hi Guys,
I had a problem with my front side-light and my brake lights which I have solved and thought others MAY benefit from this.
The problem was, when I put my foot on the brake, not only would my brake lights come on but also one of my front side lights as well. If I switched on my side lights the brake lights would also come on, if I then pressed the brake pedal the change in the brake lights was indiscernible.
Cause
In one of the taillight/brake light bulbs the two filament had distorted and were touching each other.
Solution
New bulb……”s i m p l e s”…..and just as important, cheap.T:
Keith
Cause
Solution
Keith
