I wondered if someone might be able to help with the following as I seem to have run out of ideas:
Usual flashing light bringing up error code 16955 (Brake Light Switch)
I have stripped switch and cleaned up all connections (twice!) as per excellent write up on here A:
Swapped both bulbs (brake lights have always worked fine)
Checked brake fluid level (fine)
Checked all fuses (fine)
Cleared fault code and still keeps coming back!
I bought a new switch from the dealer and they sold me part number S1C0945511ARDW which is the green switch that looks very different to original one. As they have updated switch I assumed this was the correct one but when I installed it the glow plug light doesnt come on when the ignition is turned and the van wont start, questioned dealer and he says its the right switch?
Anybody got any other ideas / experiences of what could be causing the error code? Apologies if this is answered somewhere but I think I have read every post on this and not found any other causes.
Can you get patterned 4 pin switches as all the ones I have found at factors are only 2 pin?
