Brake wear warning light on, on my 2000 reg 1.9td T4
Checked front nearside wheel and the wire has been shorted out , checked the front offside wheel and can't find a connector.
Does anyone know if there is only one wear indicator? According to my handbook they are only fitted to the front wheels.
If there is only one and it is shorted out, what else can bring the warning light on?
Front N/S rear O/S mate they are known for breaking wires I had same problem found a break in the wire aprox 2 foot away from n/s front plug where its fixed and not moving found this strange but glad to have found it :D
There are 2 positions as said above mate.
You can repair the loom, or the alarm can be turned off with vagcom.
on chuffs old van the o/s/rear had one on as well gaz, follow the wire from the wheel under the body theres a connector there that you can short out to see where the problem lies
p.s have you checked your padsI:
