Hi all.
I am down visiting people near Lowestoft and on the way my brake peddle pressure was irregular and some times the brakes would stick on enough to make the van struggle. I ended up having to pull over and pump the peddle a few times to help the problem.
All four corners would stick on. I had two rear brake pipes replaced recently. Could this have anything to do with it? Do they need bleeding? Anyone recommend a garage near Lowestoft?
Cheers.
Thanks for the help.
Guy at QuickFit says the servo is fine and its a self adjusting mechanism behind the peddle.
He does not have time to have a look at it though. Has anyone else experienced this? Is it
Something I can do myself?
