What a **** design. Went out in the van yeseday and noticed i was a little cold. so checked it out today and found that the ball end has snapped off inside the heater controls.
Is this a common fault? and i'm guessing I can only buy the controls as a complete unit and not the little cast part...
Pedal box guru
When you replace the control make sure you replace the cable as it is the cable that causes the cast lever to break. If you don't you will break the new controls too.
Cheers Trev.
