simply install a 3 pin switch near your controller
splice red wire into and run a lead to pin 1 on the switch
cut yellow wire
then connect pin2 of the switch to heater yellow
then pin3 of the switch to controller yellow
Result:
switch in position 1 everything as normal 60 min timer etc
switch in position 2 heater always on but fully adjustable (heat ) up down temp keys function as normal
switch £2.29 3 pin 12v on off on switch ebay seller radio world ebay no. 250879336977
perfect for these upcoming chilly nights !!! - enjoy - hope this fix helps you too
