1 - 20 of 25 Posts
OK Guys, bit baffled.
Just removed the RCD200 expecting to slot in the new pioneer beasty.
Errrr No.
Some sort of OEM adaptor with 3 main connector blocks in, plus a funky ariel connector.
So next question, what do i need, and where do i get it- driving to Germany in 2 days!!!:eek:
Errrr No.
I had the same problem. Stereo Steve sorted me out.
Whom is this stereo steve you speak of?
I spoke with a gent from NI car audio after reading a thread by 'Milko' and he said that a Connects2 'CTS-VW002' will do the job nicely, all the connections are there for switched live, speed pulse reverse input etc are built in.
Paul- I picked up a similar unit last night by 'Autoleads'- yes it connects, but I have no desire to have a flat battery in the morning- it doesnt do switched live, stays on all the time- I'd rather get an all in one solution.
Search for him on here. He runs inks audio in Northampton.
We did have to run an extra lead to the fuse box for ignition on power I think.
The red wire from the new connector loom needs to be wired to a ignition source. Easyest place is the back of the headlight switch. You need to connect it to the black wire with a yellow trace.
Discussion Starter · #8 ·
All sorted!!
So for those of you with a Canbus T5 wanting to install a decent stereo
THIS is what I used, very plug and play.
works a treat
Hi mate, you also need a 'Fakra' arial connector.
Have tot it up and running now, however having an issue with video at the mo- wont display!
Best place for an ignition on is here, this stays live until you remove the key
Behind this fuse
Discussion Starter · #13 ·
cheers mate, although I do fancy linking it to the Leisure batt at some point so I dont have to have the ignition on
Discussion Starter · #15 ·
May well have one at some point- until then, is that wire green & brown? Viewing on phone so not ideal quality
would you need to do much to fit a bluetooth hands free kit?
i to am about to fit a poineer double din but wanted to fit a parrot c3100 aswel
1 - 20 of 25 Posts
