Hi
Van: 1997 2.0l petrol autosleeper trident.
Hopefully someone will have an idea what the cause of the following is.
When I first turn the key in the ignition switch there is a buzzing sound from behind the speedo part of the dash and the hands on the fuel and temperature gauges as well as on the speedo itself quiver/vibrate for a few seconds. The trip counter also zeros.
I have changed the starter switch as that was faulty but the fault was there before that.
The van starts fine.
This buzzing and gauge hand vibration can't be right so I really would like to sort it.
Any leads / suggestions gladly recieved.
I have trolled the net for problems but if you know of another thread relating to this please feel free to point me to it.
I have the 2.5 petrol when i turn my ignition on there is a buzz from the fuel pump until its primed.Also there is an electric water pump that i THINK also starts up when the ignition is turned on and runs for a while when turned off too.
Dont know if the 2.0 petrol is the same though:*
HTH
Pete
